Car doesn't want to start
Old Nov 19, 2005 | 08:40 PM
smokenasty's Avatar
Car: 87 Iroc
Engine: 5.7 TPI
Transmission: Automatic
when i turn the key it starts and then it runs rough and then dies...but when i start it and give it a lil gas then it runs fine after that. Any ideas?
Old Nov 19, 2005 | 09:00 PM
91Z28TTOP's Avatar
Car: 91 Z28 CAMARO
Engine: 305 TPI,stock
Transmission: 700R4, 2800 stall
Start by checking fuel pressure, timing, condition of ignition system, throttle position sensor. How long have you had the car and when was the last time a tune-up was done. Check also the oil pressure switch. Start at the top and work your way down and eliminate the most obvious.
Then post your findings.
Old Nov 20, 2005 | 01:10 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If it starts fine when you do a clear-flood (or along the lines of), sounds like leaky injectors. Do a fuel pressure test.
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
mizz0313
Aug 12, 2015 06:45 AM
killer777
Aug 8, 2015 02:47 PM
