Need suggestions
Old Nov 20, 2005 | 07:13 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Need suggestions
Hello everybody.
I have an L98 that I swapped the intake to an LT1 intake, I also have ported the heads decently. The bottom end is stock. Next im replacing the cam. I know just about absolutely nothing about what specs I should be looking for. I want a fairly aggressive cam, nothing too over the top, for street/strip.
What should I be looking for as far as Lobe Sep, Lift and Duration?
Old Nov 20, 2005 | 07:20 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Do you have the rest of the car to go with it? Headers, converter, gears, subframes? If not, I would keep duration in the high teens, low twenties. 218/224 is a comp grind I believe. Stock heads wont take more than .480" lift without maching the guides. A hot cam is about as big as I would go for a driver with a tight converter and tall gears
Old Nov 20, 2005 | 07:25 PM
MattODoom's Avatar
Car: '88 G T/A
It has 1 5/8 shorties into single 3", 2k stall converter and 3.23 gears. Dont have SFC's yet.
How about this cam:
http://store.summitracing.com/partde...5&autoview=sku
Too big?
darwinprice
17
Oct 11, 2015 11:51 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
gord327
Oct 3, 2015 01:25 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
R13_Braz
Sep 18, 2015 05:00 PM
