Oh Sh!t
Old Dec 3, 2001 | 04:27 PM
AZ88Maro's Avatar
Oh ****
Well this morning i get in my car ready to go to school and the car wont start, when i turn the key it make a squeeling sound. Kinda like when you turn the key when the engines already running. It will squeek for a second and the stop. I know this is kinda vague but any help would be great. Thanks. Bobby.
[This message has been edited by AZ88Maro (edited December 03, 2001).]
tpi_roc's Avatar
Was it raining? Wet belts?
Could be your starter wasn't ligned up.
1985 Iroc-z, 14 second 305, new engine in the works.
Old Dec 3, 2001 | 04:31 PM
Enkil's Avatar
Hmm... It could be the starter, but it doesn't usually stop shrieking if you hold the key in the start position. If it makes the noise after the engine's started, then goes away, it could be a loose belt.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Dec 3, 2001 | 05:01 PM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
could it be flywheel related?
Old Dec 3, 2001 | 05:19 PM
tpi_roc's Avatar
very likely
that would be what the starter has to line up on
Old Dec 3, 2001 | 08:43 PM
CloudZStrife's Avatar
It's either
1) Your Flywheel which can set up back about 200-300 smackers.
2) It's your starter which could set you back about 120 without labor.
87 IROC-Z, 3.23 posi, new 305 TPI, and soon to get new trans and world torquer 305 heads
Old Dec 3, 2001 | 09:06 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You can get a rebuilt starter from Autozone for $30 w/a lifetime warrenty. I'd say Advance but, they can go f-themselves w/thier starters (I'm not bitter at all towards them ).
------------------[*]my Formula Homepage [*]Collision P/Ns & Diagrams
"Always do sober what you said you'd do drunk. That will teach
you to keep your mouth shut."
Old Dec 3, 2001 | 09:38 PM
AZ88Maro's Avatar
Ok guys how can i determine if it is the flywheel or the starter. Why would it go out all of a sudden. Can it be anything else. Thanks A lot so far guys.
Old Dec 3, 2001 | 11:34 PM
deadbird's Avatar
Engine: TPI 305/ v6
Jack the car up & take the flywheels cover off & visually inspect the flywheel for missing teeth.
While you're under there, inspect the starter for cracks too (especially if it's from Advance auto).
