vacuum ???
Old Dec 4, 2001 | 06:50 AM
gt auto's Avatar
vacuum ???
I just removed all my smog stuff and installed new injectors at the same time. I took all the vacuum hoses off and thought I would replace them all. I took some pictures of them before I took them off but messed up when I was putting them on my pc. Anyone have some good diagrams or pictures.
Thanks,
GT Auto
Old Dec 4, 2001 | 02:35 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
May catch a response if you let folks know what kind of car/yr/etc, you have.
Old Dec 4, 2001 | 03:03 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I replied to you asking that over in the TPI forum but I suppose you didn't see it..
https://www.thirdgen.org/messgboard/...ML/005562.html
That's the only diagram I have, it's from the emissions label off an '89 or so TPI camaro, I'd be almost willing to bet just about all TPI's are the same for emissions vac. routing.
------------------[*]my Formula Homepage [*]Collision P/Ns & Diagrams
"Always do sober what you said you'd do drunk. That will teach
you to keep your mouth shut."
Old Dec 4, 2001 | 06:05 PM
gt auto's Avatar
That would work. it is a 88 305 tpi motor. What I need is the hoses frome the plenum and the fule pressure reg. and the I guess check valve thing.
Old Dec 4, 2001 | 08:28 PM
deadbird's Avatar
Engine: TPI 305/ v6
The hose on the drivers side of the back of the plenum go to the brake booster
The far back line (I think) on the pass side goeas to the cruise control
The forward vac. port of the one mentioned above, towards the nose, on the pass side, back of the plenum, goes to the FP reg.
The cruise is the larger of the 2 on the pass side rear of the plenum.
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
timonator
Sep 30, 2015 12:52 PM
dusterbd
Sep 29, 2015 08:40 AM
