Vacuum Canister Part No or Name
Hi I need to install "the vacuum reserve canister for the cruise control unit" on my 87 350 TPI GTA. Can anyone tell me Where I can get this part and if you can tell me the part name or Number? This is a canister which fits in the driver side fender and connects to the vacuum line from the cuise control unit.
Prem.
Prem.
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
I would recomend just buying one out of a junkyard. The thing almost never goes bad. Your either looking for the servo unit which would be 25074627 or for the tank which is 14056624. These are Chevy's part numbers, Pontiac may use different ones. The servo looks like two hoses connect into it but I can't tell with the tank, maybe one hose. If I had a scanner I would have tried to have scanned the page and let you point out the part number, but I don't have one...
Still, check the scrap yards for the part, you should be good there...
Mike
1989 RS.. 355, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, rapidfire plugs, chevy caprice 350 chip, 200* fan switch, 3 angle valve job, 3 inch cat-back exhaust, 3 core radiator, 3.73 gearing with POSI.
Mike
1992 Trans Am
May 10, 2023 07:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
