PVC valve help.....
Old Dec 5, 2001 | 02:39 AM
missythehood's Avatar
PVC valve help.....
I was wondering what would happen if I did not use a PVC valve? Would it be bad or good? If I can do that should I take off the EGR valve? O yea it is an 86 IROC-Z 305 TPI.
Old Dec 5, 2001 | 04:58 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
There are no advantages to removing the PCV valve. You'll get a lot of buildup in your engine, plus excess crankcase vapors. So basically that's bad. As for the EGR, you could remove it and put a block-off plate in it's place, but it really won't help with power or gas mileage. What it will do is give you a service engine light.
91 Z28
Come see The Vicious...
Old Dec 5, 2001 | 07:49 AM
82resto's Avatar
The PCV valve is nothing but good for you. Don't remove it.
Jon
89 GTA
Beautiful Gunmetal gray, LB9 305 and T5 tranny. Only 60,000 miles!
Dual cats, 3"flomaster
Accel 300+ Ignition, wires, cap, coil, etc
Airfoil
KN Airfilter
Removed Screens on MAF
SLP 1 3/4 headers
No Smog/AIR system
14.7@93 (I know i should be running faster...)
91 Ford Thunderbird. My wonderful winter beater.
Old Dec 5, 2001 | 02:07 PM
snakeskinner's Avatar
yeah, you can remove the PCV valve (PVC is plastic) but you'll shortly be replacing all the gaskets in your motor after they blow out. Most high performance engines have crankcase ventilation systems that use pumps to relieve pressure, PCV is a downgrade from that. Before PCV they used a downdraft pipe that stuck down under the engine and used the air rushing by the pipe to pull the air out of the engine. PCV sucks not only the pressure out of the crankcase but the volatile fumes which can also ruin gaskets and could possibly cause combustion problems. EGR helps eliminate detonation during street driving by lowering the combustion temperature which also cuts down on power. if you had a car that doesn't get driven that often and you wanted performance, you could block off the EGR but it really wouldn't help any. The only benefit would come if you were to remove the heads and fill the exhaust crossovers to eliminate the center two ports from robbing each other and the turbulence caused by the crossover ports. as well as the heat in the intake manifold. the service engine light should also light too.
Kyle Osterholt
Okarche, Oklahoma
ASE Master Certified
86 T/A 383 TPI
89 TTA #1002 T-top/Leather
89 TTA #1358 Hardtop/Leather
80 T/A Pace Car
73 Opel GT
73 bronco
2000 Ducati 996 Monoposto
83 MSE #52
Old Dec 5, 2001 | 03:14 PM
82resto's Avatar
You have two TTAs?????!!!??? You bastard! Didn't your mother teach you how to share? Like with me? Man, I would give you my GTA and a whole lot of moola for one of those...
Jon
89 GTA
Airfoil
KN Airfilter
SLP 1 3/4 headers
No Smog/AIR system
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
Formula8r89
Sep 22, 2015 04:24 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
