Weak Heater
Old Nov 26, 2005 | 11:49 AM
Hoop88Z's Avatar
Car: 1988 IROC -Z28
Engine: 5.7L TPI
Axle/Gears: 2.77
Weak Heater
OK have an 88 IROC and the heater is just a little....lot weak. I was just wondering if there is any kind of aftermarket solution or replacement for the heater core perhaps an all aluminum one, that would make the heating system a little bit more efficient. Now that it's cold I can barely get the heater to warm up when the car is moving...when it sits still for a little while it heats up nicely, but once I get going, the heat gets going too..I'm tired of freezing my *** off. Can this be helped or do I just have to start layering my clothing more effectively?
Old Nov 26, 2005 | 11:53 AM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
It might be the heater core is blocked, they tend to sludge up after a few years.
I assume the thermostat is opening and closing ok?
Just done one on a Daewoo , it was freezing inside the car, and running on choke a lot, all due to a £10 thermostat.
Old Nov 26, 2005 | 12:03 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If the fan blows good still, I would start with a heater core flush.
Falcon50
Aug 22, 2020 03:26 PM
lanceflame44
Sep 25, 2015 12:28 PM
