timing problem please help
Old Nov 24, 2005 | 08:43 AM
j88l98irocz's Avatar
Car: 88 IROC-Z twin turbo
Engine: forged 383 8-1 compression
Transmission: t56
Axle/Gears: 9in 3.50's trac loc moser axles
I have an 88 iroc it is a 350 tpi car i just completed putting the new engine in the car runs, but I cant set the timing right, with the electronic advance unplugged the car will not start and if i unplug it when it is running it just stalls any ideas ???
Old Nov 24, 2005 | 09:11 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Are you setting it with the EST wire unplugged?
Old Nov 24, 2005 | 02:04 PM
Transmission: t56
what is the est wire ?
Old Nov 25, 2005 | 01:07 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
It controls the electronic spark atvance. Its usuallly a single brown wire on the passenger side of the engine compartment. Unplug it and then set your timing. Then plug it back in.
Old Nov 25, 2005 | 04:48 PM
Transmission: t56
that is the wire that I am talking about, whenever I unplug it with the car running it stalls. If I unplug the est wire when the car is off and try 2 start the car cranks over but wont start, as soon as I plug the est wire in the car starts right up ????????????
Old Nov 25, 2005 | 05:27 PM
Vader's Avatar
Get it started and running, THEN disconnect the EST bypass. If the engine stalls, reconnect the EST, advance the distributor about 10°, then try it again. The base timing is just way off right now, so a little more advance should get you running enough to set it with the light.
Old Nov 25, 2005 | 07:13 PM
Transmission: t56
I will give it a shot ,thanks
Old Nov 26, 2005 | 12:34 PM
JADIII35's Avatar
Car: 1991 trans am
Engine: 383
I actually just had this problem myself. I went ahead and unplugged the EST and had a friend crank the car over while I used the timing light to see where I was at (car wouldn't start). I was about 10* retarded. Needless to say I needed to bump it up a bit. My situation was just like yours, would run with the wire connected but not disconnected.
Old Nov 26, 2005 | 01:38 PM
Transmission: t56
I did what you said and it worked thanks.
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
