Water Pump, isn't there a lil valve that leaks when broke?
Isn't there this little thingy that like breaks or falls out when your pump goes bad, to let you know its time for a new one. Cuase I'm pretty sure mine is leaking everywhere and its hella over heating fast.
un4givin89
Poor Mans White Face Guages
MikeKey.net - Camaro Enthusiast
un4givin89
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Usually what happens is, it starts pissing coolant out of the bearing vent hole on the bottom of the pump.I think this must be what you're referring to.And, yes it sounds like it's time to replace it.
Check out Stewart Components for a much better than stock pump for a reasonable price.
http://www.stewartcomponents.com/index.htm
-Rich-
-Rich-
Car: '94 Corvette
The manufactures put this hole there to prevent antifreeze from getting to the pump bearings. So it go, seal--weep hole--bearings. If the antifreeze were to get to the bearing they would seize in short order.
I personaly like the Edelbrock Victor Series water pumps.
They start at about 150 bucks.
Ron
'82 Trans Am
'81 Camaro Z-28
'94 Vette LT1 Coupe
'00 Impala LS
Ron
'82 Trans Am
'81 Camaro Z-28
'94 Vette LT1 Coupe
'00 Impala LS
Damn, guess I'll be carrying water jugs till this weekend when i get free time. guess I'll place my order.
un4givin89
un4givin89
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
