Bolts
Old Nov 27, 2005 | 01:01 AM
BanditMan's Avatar
Car: 84 trans am
Engine: 305 H.O. with small cam
Transmission: th350 with manual valvebody
Axle/Gears: 3:73's
Bolts
Ok, im about to get my new tranny to put in my car, and when i pulled it, i put all the bolts together, but in the past month or so, theve got knocked around and scattered, and im just about positive that half of them have been lost. I need to find an exploded view or something of the bellhousing, all the way back to the driveshaft. I planned on replacing all the hardware anyways. I just dont wanna get under there and find that im missing a bolt and have to go back and forth to the hardware shop.If nobody knows of such, i guess i can provide a list of what i need to know, thanks, Jeremy.
Old Nov 27, 2005 | 05:09 AM
ede's Avatar
ede
you'd need a set of flywheel blots ,a set of pressure plate bolts, or fly wheel bolts/nuts, look at ARP hardwear bolts won't work. you'd need 3/8-16x1.25 or 1.5 for the trans to block
Old Nov 27, 2005 | 02:15 PM
BanditMan's Avatar
Car: 84 trans am
Axle/Gears: 3:73's
aight, thanks man. I went and picked up a haynes manual today, and it has several exploded views in it, so i found everything i needed.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
