Torque Converter?
Old Nov 27, 2005 | 07:33 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Torque Converter?
My '92 Formula might have a torque converter that needs replacing, but I am not sure if that is the problem. I am hoping that if I describe my symptoms, then someone here might be able to tell me what the cause might be?
At idle in gear, the car seems to have a slight lopiness, or shudder. This seems to disapper if the trans is placed in neutral or park
On the road, if accelrating rapidly, either from a stop or from 60 mph, the car has a pronounced shudder. Accelerating gently and slowly makes the shuddering disappear. The shudder seems to be more noticeable when driving in the OD gear, but it is also present when in D.
So, does this sound like a converter issue?
Old Nov 27, 2005 | 08:10 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Sounds like it could be a converter. Could also be a bad pump bushing or many other problems.
Old Nov 27, 2005 | 08:29 PM
spedrace35's Avatar
Car: 91 camaro z28
Engine: 6.3L, heads, headers, cam,.....
Transmission: 700-R4 w/shift kit and 3-4 WOT kit
Axle/Gears: 4.11
I had a torque converter that went out of me once, you will know if it is the torque converter because the problem will continue to get worse until it gives out. When you can feel a slip from the trans when your accelerating from a stop that’s when you know its the torque converter. Don’t do what I did and wait till the torque converter gives out!! O and by the way when all this was happening I never heard a "shudder" sound or any sound it was just the felling of something slipping. I hope this helps.
Old Nov 27, 2005 | 11:02 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Check the secondary side of the ignition system
Plugs, wires, cap rotor
seiplentz
Aug 19, 2019 06:02 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
