Fuel Question
Old Nov 27, 2005 | 08:32 PM
Firebird Pat's Avatar
Car: 1985 Firebird/TA
Engine: 5.0 liter/TPI
Transmission: auto
Fuel Question
Car wont keep an idle. Checked fuel pressure and it read 9-10 lbs
I have a stock 1985 firebird t/a 305 tpi, fuel is flowing, all injectors
clear, I think pump is getting ready to go... Shouldn't I have more
pressure? like 20 lbs ?
Old Nov 27, 2005 | 09:16 PM
Firebat's Avatar
i'm thinking more like 30-45. I dont know though, i never checked mine. 9-10 isn't right at all though for tpi. Replace your fuel filter first, located towards the rear of the car, on the fuel line. If that doesn't work, replace the fuel pump.
jandl22's Avatar
Car: 82 White Stock Camaro
Engine: 2.5 151 TBI
Transmission: 4 Speed Manual
Re: Fuel Question
Is seems as though you have answered your own question, the pump is ready to go! But make sure you check the fuel filter first!
Old Nov 27, 2005 | 09:27 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
305 and 350 TPI factory fuel pressure is 43.5 psi. You are no where close to the correct fuel pressure. So, yes, change out the fuel filter, then check the fuel pressure again. If not around 43.5 psi, then maybe it is the fuel pump in the tank.
If you do change out the fuel pump, you might as well install one that flows alot more than the factory pump.
Old Nov 27, 2005 | 09:33 PM
Firebat's Avatar
i recommend a Walbro fuel pump. Just cause thats what i got.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
fasteddi
Sep 2, 2015 10:29 AM
redmaroz
Aug 16, 2015 11:40 PM
