'77 350 motor?
Old Nov 28, 2005 | 07:20 PM
91WhiteCamaro's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
'77 350 motor?
ok, i just recently found my engine code located on the passenger side in front of my valve cover. the number is V0404CLD. im not sure if they are zeros or o's, but all the sites i look at say the last 3 numbers/letters tell you what it is. well when i looked it up it says its a 1977 350 vette engine. that HAS to be wrong, because i don't think that adds up at all... can someone help me out with this dilemma?! im so confused.
Old Nov 28, 2005 | 11:09 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
to clarify, where did you get your casting number from?
I use this place to find all my casting nubers and it has never let me down:
click Here to find your actual number
and here for where to look for them
Old Nov 28, 2005 | 11:22 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
The "CLD" was indeed a L82 350 vette motor.
It was in both 73 and 77 vettes, pushing 250HP in '73 and a wimpy 210HP in '77.
Looks to me like a #4 code off of the front of the block, just infront of the heads mating surface.
Old Nov 29, 2005 | 10:20 AM
Car: 1991 Camaro RS
Engine: 305 TBI
right, in that diagram it was number 4. in front of the valve cover on the passenger side, just below the air compressor.
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Out-Cast
Aug 17, 2015 10:57 AM
st.evel07
Aug 13, 2015 06:15 PM
