Small dent in one of the cylinders
Old Nov 28, 2005 | 08:02 PM
rjpbboi's Avatar
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
I just noticed a small dent in one of my cylinders, looks like the cause came from the outside, I'm just wondering if this effects performance a lot. I'll have a pic up tommorrow.
Old Nov 28, 2005 | 08:37 PM
Vader's Avatar
Dent in a cylinder, or in an intake runner? A small dent in a runner will make no real difference.
Old Nov 28, 2005 | 09:05 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
if its in an actual cylinder, thats bad
otherwise your fine
Old Nov 28, 2005 | 09:11 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
If its a cylinder the piston will either wedge in there and seize up the engine or it will wear a big chunk out of it...
I would imagine your talking about one of the TPI runners, if somethings gone through the block and dented the cylinder and your asking if its ok you need you head examined
Old Nov 28, 2005 | 10:40 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
Im wondering if youre not saying "cylinder" but meaning "piston". small dents in the top of the piston shouldnt make much of a differece, but i would definately want to find out what made the dent. if you've got stuff flying around in the cylinder with a piston traveling < 1000 mph like they do, i'd be afraid of that "stuff" making making more than "dents".
Old Nov 30, 2005 | 09:54 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Stop giving Taxachusetts a bad name.
So what exactly has the dent?
db057
Apr 28, 2019 07:45 AM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Jorlain
Oct 8, 2015 01:57 AM
ericjon262
Sep 11, 2015 06:07 PM
