DD2005 results for my motor
Old Nov 30, 2005 | 07:53 PM
spedrace35's Avatar
Car: 91 camaro z28
Engine: 6.3L, heads, headers, cam,.....
Transmission: 700-R4 w/shift kit and 3-4 WOT kit
Axle/Gears: 4.11
Well this is what Digital Dyno is stating what I will make, I was hoping for little higher numbers!!! O well, I know that this is just an estimated number. O one more thing; when I bought the car it already had aftermarket injectors but I have no idea what they are rated at. Does anyone know a good way to find out? Ok well if you guys have any comments (good or bad) let me know. O and yes I will get an aftermarket throttle body but Ill do that a little down there road. Talking about that DD2005 also stated that I would only make an extra 10hp with a TB that flowed at 1000cfm (stock tb is rated at 650cfm). Does that sound right to you guys?? Well just let me know what you think.
Old Nov 30, 2005 | 07:55 PM
spedrace35's Avatar
Car: 91 camaro z28
Axle/Gears: 4.11
here some more info
Attached Thumbnails DD2005 results for my motor-dd2005-dyno-results-w
Old Nov 30, 2005 | 08:51 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Ohh. DD2005 looks impressive. Things like being able to play with ignition timing now looks promissing plus a few other options that were not available in DD2000. Looks like another program I need to get my hands on.
I see in your screen capture that you have crank timing for ignition. Your engine uses a crank trigger to fire the ignition?
Increasing the CFM up that much normally won't show a big increase in performance but you would probably notice a big change in the way the throttle response is in the real world. It also depends on how much the engine really wants. At only 10.2 compression, a bigger CFM would like more compression, cam, heads.
Old Nov 30, 2005 | 09:47 PM
spedrace35's Avatar
Car: 91 camaro z28
Axle/Gears: 4.11
Thanks for the feed back Stephen87IROC. To answer the timing question I actually don’t know what is used for timing I just picked it. Something I need to do more research on. Currently my ignition is stock planning on upgrading after my car is running and have some money again!! I’m sure you guys know what I’m talking about! I really wanted to go with a higher compression but I want to use pump gas, as for now this will be my daily driver. This explains why I got a smaller cam as well. When the times comes close for my car to fire up for the fist time Ill be in here again asking questions about timing. Any suggestions were I can start researching this topic? But thanks again for your input.
Old Nov 30, 2005 | 09:58 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Since I don't have DD2005, I don't know what options are available for all the choices.
Your base timing of 8* and total timing for 36* should be pretty close. Try dropping the total down a couple of degrees and see if the HP level increases. Finding what timing works best is almost a trial and error method. What works well in one car might not work fo another.
My base and total timing is 36*. My distributor is locked out to full advance. Is it the best position? I don't know. The best place to find out is on a dyno but now with DD2005 giving you a timing option, you could probably get very close to what the engine likes best before firing the engine up.
Old Nov 30, 2005 | 10:06 PM
spedrace35's Avatar
Car: 91 camaro z28
Axle/Gears: 4.11
Thanks a million for the great advice, o and just to let you know you can down load a trail version of dd2005 that is what i did!! Thanks again
Old Nov 30, 2005 | 10:18 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
you get 5 free runs on the full version for free.
My trial version has been running for about a week, i still have 4 more "runs" left. As long as you keep the program open you can do as many as you want!
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
michealleger
Aug 26, 2015 03:29 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
