Leak?
Old Dec 6, 2001 | 08:13 PM
86BIRD-MY FIRST CAR's Avatar
Leak?
I parked the car for about 15 minutes and when i cam e back there was a pool of black fluid underneath the left tail pipe next to the gas tank. now where it came form i have no clue....and yes it is from my car
86 firebird 2.8
K&N replacement filter
modified air box
MSD ignitor
Hooker cat back
GNX style wheels
Old Dec 6, 2001 | 08:48 PM
DiecastZ28's Avatar
I can tell you its oil. Just cant say why.
1985 Camaro Z28
305
5-speed Transmission
Flowmaster Exhaust
4 barrel carb
8mm wires
Kenwood 600 amp
Sony Deck
4 6x9 Jenson Speakers
2 4x6 Polk Audio
2 10" JL w0 Subwoofers
Old Dec 6, 2001 | 09:16 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Check and see if its still there, and not just a black spot.
If its still there, does it feel like water??
Moisture is biult up in the exhaust, it always finds the seams of the ex. pipe and leaks out. The blackness is caused by the "soot" in the ex. pipe.
No biggie, nothing is wrong.....unless you fell it and its oil...then check back in.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Dec 6, 2001 | 09:19 PM
its kinda watery but smell like burnt oil, is that normal?
86 firebird 2.8
modified air box
MSD ignitor
Hooker cat back
GNX style wheels
Old Dec 7, 2001 | 07:32 AM
82camaro's Avatar
Car: 82 camaro SC
Sounds normal to me. The water is just moisture built up in the exhaust. The black is carbon in the exhaust that the water flushed out. Short trips can make the moisture build up quickly.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
[This message has been edited by 82camaro (edited December 07, 2001).]
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
