Is it supossed to be like that (vacum)
Old Dec 7, 2001 | 03:12 PM
88camaro's Avatar
heres a pic is it supposed to be disconnected ?
i dont know how to post a pic so i'll just put up a site
http://www.geocities.com/camro1988/i...1007760318963/
(and i know it's spelled camaro not camro, i just registered that way)
[This message has been edited by 88camaro (edited December 07, 2001).]
Old Dec 7, 2001 | 03:20 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes, it is supposed to be hooked up. It is not supposed to look like it does in the pic.
The nipple on top of the control valve for the hose is broken off.
ICON Motorsports
Old Dec 7, 2001 | 03:27 PM
88camaro's Avatar
could it be the cause for the bad gas milage , how can i fix that
Old Dec 7, 2001 | 07:24 PM
88camaro's Avatar
can anyone help?
Old Dec 7, 2001 | 08:59 PM
BleedingKnuckles's Avatar
I think my mechanic disconnected one of those lines on my car so that I would pass emmissions. It creates a vacuum leak, I guess reducing the amount of vacuum advance applied. It probably is effecting your gas milage for that reason. If you plug it in you should be able to hear the difference in your idle depending on how you have your lines routed. It smoothed out my idle when it was connected.
84 Camaro Z28
350 4 bolt main with 305 heads
Engle Cam 210/216 @ 0.050
K&N Filter
Weiand Action Plus intake
Accel Supercoil
Suspension Techniques lowering springs
Energy Suspension bushings
Corry
Aug 26, 2001 11:26 PM
rscamaro91
Aug 13, 2001 08:41 PM
Stell1579
Carburetors
Jul 2, 2001 11:25 AM
ArnoldBraker
May 14, 2001 10:45 AM
91Z28
Feb 23, 2001 11:04 PM
