1/4 mile time?
Old Nov 30, 2005 | 07:21 PM
silvergta's Avatar
Car: 1987 Trans Am GTA
Engine: Stealth Ram 383
1/4 mile time?
My GTA is a 355 bored 30 over, has 10:1 compression, a cam thats a little bigger than stock: 214/224 duration .443/.465 lift, hyper tech stage 2 chip/170 thermostat, edelbrock shorty headers, 3" flowmaster all the way back. I was wondering what all you's think this should run in the 1/4 mile. My best so far is 14.2, and i think it should do better, atleast high 13's. Appreciate the help!
Old Nov 30, 2005 | 09:29 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
You are running a bigger duration cam than I'am and 5 more cubes. The results are in my signature.
Old Nov 30, 2005 | 10:21 PM
silvergta's Avatar
thanks for the info. You said you are looking to get a Comp Cam 268XFI HR13 cam, i was wondering how big i could go with a cam without having to get new heads? I appreciate your help!
Old Nov 30, 2005 | 10:26 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
It would be nice to know what heads your running!
Old Dec 1, 2005 | 07:53 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
those headers always seem to come up in the sig. of these cars that don't seem to have all the hp they should be making just a thought. however the hypertech doesn't help much if any. the flowmaster is a hold back too.
now I assume you are using the stock gta l98 iron heads? not TBI swirlports I hope
just a thought. also your ign timming plays a BIG part in making hp. too much and you pull timming and actually build max pressure pushing back on the pistion. too little and you never burn all the fuel.
more often than not I see people with too little timming (you know these guys with all the popping and crackle noise
Old Dec 4, 2005 | 08:25 PM
silvergta's Avatar
88 350 tpi formula:
"those headers always seem to come up in the sig. of these cars that don't seem to have all the hp they should be making just a thought. however the hypertech doesn't help much if any. the flowmaster is a hold back too."
yea i have heard that about those headers too, the guy who had it before me got them. I am looking at getting a better chip though, maybe a custom burned chip. I really dont know too much about custom burned chips, but i'm looking into it. I have also heard that flowmaster can be restrictive on SOME cars, but not my car.
As for the heads, they are the stock l98 heads.
Old Dec 8, 2005 | 05:31 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Where do you live? I ran a 14.004 on a stock head, stock cam 87 TPI with headers K&N filters, 2.5in single exhaust with a custom made glasspack, 3.27 gears, and an MSD box at Edgewater in Ohio on a TERRIBLE track. Your altitude makes a big difference in how the car will run, and you probably need to check the cars tune. I'm positive I can break into high 13's on a completely stock engine with bolt ons, as a note I ran a 13.223 on nitro the same day running out of gear a little past the 8th mile and riding it out off nitrous (to give you an idea how bad the track was) my best 60 foot time that day was a 2.01 and that was off nitrous, you should most definetly be able to break 13's regardless of where you live, how was the weather the day you ran?
Old Dec 8, 2005 | 08:14 PM
silvergta's Avatar
Yea, i'm pretty sure it has a lot to do with the timing too. This summer i will go to the track and a buddy of mine is going to adjust the timing for me and we'll see what happens. I also have a K&N filter, i took the air box off so its out in the open. As for the weather, i ran it all through the last summer, so it was hot some days, and cool others (around 65-70 degrees), but i'm not exactly sure what the temp was.
Old Dec 10, 2005 | 06:22 AM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
im gunna say ditch that hypertech like he said above. My friend had one and when he pulled it out the car ran 1/10 faster without it.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
evilstuie
Jan 9, 2020 08:29 PM
Andrew6.688
Dec 13, 2015 10:59 AM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
