help with comprssion
Old Nov 30, 2005 | 08:54 PM
slapi01's Avatar
Car: trans am
Engine: sbc350, afr 180cc head, comp full roller, xtrem 276,comp 1.6 roller rockers,weiand142
Transmission: tremec tko
Axle/Gears: 8.5 3.73 gear, moser 30 spline axles,eaton posi
i have a 350 sbc with 9.1-1 compression with 64cc heads. if i changed to 74cc heads, can anyone out there tell me where my new compression might fall? i am using a regulars head gaskets and nothing is getting done to the block itself.(decked,whatnot) i know there might be more info needed so fire away
Old Nov 30, 2005 | 09:18 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
http://www.camaroz28.com/services/calcs/
There you go, click on compression ratio calculator.
Old Nov 30, 2005 | 09:36 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
If your compression ratio is 9:1 now with 64cc heads.
Changing the heads to 74cc will drop the cr to 8.2:1
Old Dec 1, 2005 | 05:29 AM
slapi01's Avatar
Car: trans am
thank you for the quick reply.. you guys are the best
Old Dec 1, 2005 | 05:47 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
8.00:1 is the correct answer.
Nice CR for a supercharger.
Old Dec 1, 2005 | 06:23 PM
slapi01's Avatar
Car: trans am
that is exactly what i am putting on. i decieded to go with the afr's and it only took 11 weeks to get them. it was a long wait, but by the looks of them i should be happy.
BBCpoweredZ28
Mar 3, 2011 02:10 PM
xfactor200289
May 10, 2009 03:16 AM
bluechevy194
Oct 26, 2006 01:15 AM
danzig27
Nov 12, 2002 10:53 PM
