Questions about removing smog pump...
Old Dec 3, 2005 | 04:14 AM
LVZ2881's Avatar
Car: 1988 IROC
Transmission: 5 speed
Axle/Gears: 3.08 Posi 10 Bolt w/ aluminum drums
thje physical removal is fairly straight forward, and I have found the belt info in the FAQ's,and I know it will set an SES light, but my question is this...
does it have to be "deleted" from the chip??
or will the car run ok with no ECM mods??
Old Dec 3, 2005 | 09:35 AM
Vader's Avatar
You can "dummy" the wire harness with a 47 ohm resistor to emulate the port/divert solenoids. That may solve the error code problem.
As for the actual air injection,your cat converter may not operate at full effectiveness without the sir supply, if you happen to have a cat with an aspirator tube.
Old Dec 3, 2005 | 09:47 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
may not is an opinion
theres billions of cat vehicles that never got AIR system equipped
and they work just fine
good luck
Old Dec 3, 2005 | 10:18 AM
Vader's Avatar
good luck
Absolutely. I'm just not certain if the '88 models were among those that got a monolythic cat or the closed 3-way, or if they had the AIR tube. Quite a few models of that vintage still had the tube, like most Nopars and some Dorfs.
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
