LG4 weak areas
Old Dec 9, 2001 | 03:59 PM
GregN's Avatar
LG4 weak areas
Hi all. I just bought an '84 Berlinetta LG4 with about 100k miles on it. The engine seems to run fine short of needing a tuneup. What are the weak areas and easiest things to fix (read: inexpensive) on this motor? I don't want to "build" the motor but want more than the measly 150 hp that it puts out. How well will drop-in/bolt-on items like K&N, Flowmaster, headers, etc. work? It has the 4-bbl quadra-sh*t on it and I due to local laws can't remove all the emissions crap.
Old Dec 9, 2001 | 04:18 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
<font face="Verdana, Arial" size="2">Originally posted by GregN:
Hi all. I just bought an '84 Berlinetta LG4 with about 100k miles on it. The engine seems to run fine short of needing a tuneup. What are the weak areas and easiest things to fix (read: inexpensive) on this motor? I don't want to "build" the motor but want more than the measly 150 hp that it puts out. How well will drop-in/bolt-on items like K&N, Flowmaster, headers, etc. work? It has the 4-bbl quadra-sh*t on it and I due to local laws can't remove all the emissions crap.</font>
Just about everything is weak on the motor. The q-jet actually is a very good carburetor when tuned correctly. I would suggest getting headers first followed by a cat-back, I prefer the Hooker cat-back. Get the cheapest one and have it welded on, that's what I did, $200 for the cat-back. Sounds better and looks better than flowmaster in my opinion. There are soundclips of it on the exhaust board. A cam change would also definately wake the motor up.
2 Tickets to game= $250
Gas= $20
Sitting 20ft. from MJ= Priceless
'86 IROC T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK HEADERS Hooker CatBack
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Dec 9, 2001 | 06:08 PM
GregN's Avatar
So they sell headers that have provisions for the emissions crap (O2 sensor, AIR tubes)?
Greg N.
1984 P.O.S. Berlinetta LG4
Old Dec 9, 2001 | 06:32 PM
Ragin'87's Avatar
yes, yes they do. Edelbrock TES, SLP, Dynomax, Hedman, they all make headers with AIR and O2 provisions.
Anthony
previous ride: 87 Camaro LT
350, A4.Comp Cams 268H, Edelbrock Preformer intake, Hedman Headers and y-pipe, gutted cat, No AIR/smog pump. 14x3" Open element K&N, Q-jet w/ D hanger and DA rods, adjusted AV spring tension and quick can.
Current ride: 1992 Camaro RS, K&N, Flowmaster, 305, T5, Black, T-tops, 84k miles.
Falcon50
Aug 22, 2020 03:26 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
lanceflame44
Sep 25, 2015 12:28 PM
