What is this called?
Old Dec 5, 2005 | 02:02 AM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
There is alot of anti freeze leaking.. I know what and where it is leaking from. I know I have to change the lower heating hose and heater valve because that hose connects to some fitting that screws into the intake manifold behind the right side (passanger side) of the TBI unit.. I need to know the correct term for that part because it is the part that is causing the leakage!! the fitting... anyone got any clues????
(THIS IS AN OLD PIC,MY ENGINE LOOKS A BIT DIFFERENT NOW MUCH MORE CLEANER THE TBI UNIT AND INTAKE MANIFOLD HAVE BEEN REPLACED WITH BETTER STUFF)
I think there are different sizes for that fitting,I still have a stock intake manifold but aluminum, if anyone knows please inform me!
Thanks!!!
305 TBI
700R4
1991 RS
Old Dec 5, 2005 | 02:10 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
The part circled is the heater control valve. The part number is 14101545 (dealer).
Old Dec 5, 2005 | 02:49 AM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
its not that
theres a hose that connects to the heater control valve and that hose connects to some fitting that screws into the intake manifold thats what im trying to find out..
Old Dec 5, 2005 | 03:29 AM
91Z28TTOP's Avatar
Car: 91 Z28 CAMARO
Engine: 305 TPI,stock
Transmission: 700R4, 2800 stall
Just taking a gander but if your talking about the hose that runs from the heater control valve to the dohickey on the intake manifold, I would guess it could be the choke thermostat. It's part of the emisions system to heat the throttle body. On TPI units the hose runs from the heater control valve to the side of the throttle body. According to the Autozone web site there is no part number available. Kragens web site was having a blond moment and wouldn't let me check them out. If this is what your talking about it sounds like either a trip to the bone yard or the dealer.
Old Dec 5, 2005 | 08:53 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Originally posted by Psycho_91Camaro
its not that
that's funny, that is what i have always heard it called. that is also what the dealer called it when i had to replace mine.
Old Dec 8, 2005 | 05:24 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
I know what you're talking about, no clue what it's called, heater control valve nipple maybe??. I have one here from my old TBI setup if all else fails, is it cracked, or leaking at the threads?
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
bschmale66853
Sep 30, 2015 08:11 PM
