how many amps?
Old Dec 8, 2001 | 06:51 PM
88greyiroc's Avatar
how many amps?
how many cold cranking amps should my battery be able to produce ?i also have a super coil so a good strong battery would be a good idea.
1988 Iroc-z (Gun MetaL)
350TPI (38K MILES)
700r4 stage 2 shiftkit
3" cat back exhaust
K&N
Mod Chip
8.8 Race Wire
accel everything
2.77 limited slip
T-Bar roof
Old Dec 8, 2001 | 08:52 PM
82camaro's Avatar
Car: 82 camaro SC
CCA are just for starting. Without a huge stereo system, a standard battery will do you just fine. Once your car is running, the alternator is supplying the power.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Dec 9, 2001 | 01:37 PM
88greyiroc's Avatar
i posted this because my guage for my battery has been goin nuts and i didn't know if my battery is too small or if the alternator is goin because the car has to have enough power to produce a good spark to create my horsepower.
350TPI (38K MILES)
3" cat back exhaust
K&N
Mod Chip
8.8 Race Wire
accel everything
2.77 limited slip
T-Bar roof
Old Dec 9, 2001 | 01:48 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
The guages in our cars aren't that accurate. So I wouldn't really worry, as long as your car starts fine and nothing seems different.
2 Tickets to game= $250
Gas= $20
Sitting 20ft. from MJ= Priceless
'86 IROC T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK HEADERS Hooker CatBack
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Dec 10, 2001 | 07:19 AM
82camaro's Avatar
Car: 82 camaro SC
If you have any doubt about the alternator and battery, just get them tested. Most places will do it for free.
82camaro
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
