tires
Old Dec 10, 2001 | 10:24 AM
john72ss's Avatar
tires
why are my tires wearing out mostly the front ones have lots of wear on the outsides only... psi is set to 35 these tires are only 6 months old... before them i had a set of jokahamas!! they only lasted for 4 months and then the right front blew out!! 85 Z28/305/tpi/auto
Old Dec 10, 2001 | 10:26 AM
82camaro's Avatar
Car: 82 camaro SC
How is the alignment? What are the alignment settings?
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Dec 10, 2001 | 10:28 AM
tpi_roc's Avatar
Exactly
Next time you get an alignment ask for a custom camber, change it a few degrees and ad some toe in for good high speed measure.
1985 Iroc-z, 14 second 305, new engine in the works.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
mattcanty
Oct 12, 2015 11:08 AM
