Can bumps cause knock??
Old Dec 10, 2001 | 03:17 AM
83Z28's Avatar
Whenever I drive for over and hour my car has a tendency to knock when I hit a bump on the freeway. I switched to 92 octane and that helped for a while, but now it seems to do it more often, no matter what kind of gas. It only knocks once right after the bump, what the heck is goin on??
Old Dec 10, 2001 | 01:11 PM
Damon's Avatar
Try checking your trans mount. They'll give you a good "thump" once it a while. Also, look for exhaust components that can bump against stuff- like where it goes over the rear axle.
A bump in the road can not cause detonation inside the engine.
Old Dec 10, 2001 | 01:28 PM
83Z28's Avatar
At first I thought it wasn't detonation either, but sometimes it occurs without a bump. It seems to be triggered by bumps, but it also happens occasionally at slow speeds on smooth roads. Also, it never does it when the motor is cold, I figured it wasn't something hitting something else.
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
bigjay89gta
Oct 15, 2015 08:04 AM
1HotZ28&SS
Sep 28, 2015 08:58 PM
efiguy
Sep 27, 2015 01:30 PM
