Some Waterpupm questions.
Old Dec 10, 2001 | 08:31 AM
88firebird305's Avatar
Well I have to replace my water pump,just some questions. I aw some aftermarket ones selling for like $20 more then a stock one, so why wouldn't I buy a higher flow one. What brand and model is everyone running. Also I have a serpintine belt system so I have a reverse flow turn? Am I right on this? also do the aftermarket ones have a hook up for the heat on them? Thanks everyone
Old Dec 10, 2001 | 09:15 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Stewart Components makes really good pumps for a reasonable amount of $.Check them out at:http://www.stewartcomponents.com/water_pump.htm
I've used their pumps for a few years and they've been great.
-Rich-
Old Dec 10, 2001 | 09:23 AM
un4givin89's Avatar
I have to replace mine too, i was just about to post on this topic. Is mine a SB Chevy short style or long style??
I'm thinking of a weiand or edelbrock water pump. Whats a good one to get, anyone give me a product number to check out. I have LO3 engine. Looking for something better than stock that flows and pumps more.
un4givin89
Poor Mans White Face Guages
MikeKey.net - Camaro Enthusiast
Old Dec 10, 2001 | 09:24 AM
I looked at the stewart page witch length would i go with?
the
6.932" length
5.795" Length
Part number would help if anyone has it, I think stage one would be enough.
ALSO
I see they have larger water passages, do you need to get fatter hoses, or is it just inside diameter that is bigger?
[This message has been edited by 88firebird305 (edited December 10, 2001).]
Old Dec 10, 2001 | 10:05 AM
Car: 92 Camaro RS
For a thirdgen car,the correct Stewart Pump (Stage 1) would be part#13123 for serpentine (1987+) or Part#13113 for std rotation v-belt.Both are Long style pumps (6.932").
-Rich-
[This message has been edited by RICH92RS350 (edited December 10, 2001).]
Old Dec 10, 2001 | 12:41 PM
So it looks like stewart is our only choice?
I checked out weiand site and they all say not for use on serpintine system ccw rotation. Are there any other choices?
Old Dec 10, 2001 | 12:51 PM
un4givin89's Avatar
can't be right, I was looking at an edelbrock and it is long style should work
un4givin89
Old Dec 10, 2001 | 01:29 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Yes, Edelbrock makes a high volume pump as well. It is a Victor series and it is also Aluminum. I have one on my GTA. It seems to work very well and looks very nice (see pics at site) but mine is a v-belt setup. They make them for serpentine systems as well.
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
raymondandretti
Sep 27, 2015 06:43 PM
apie2546
Sep 20, 2015 01:03 PM
