383TPI/T5, balancing & shrapnels?
Old Dec 10, 2001 | 04:18 PM
Flfinn's Avatar
Car: GTA '88
Engine: 420 Dart SHP
I'm building a 383TPI w/ Eagle 383 crank out of a '88 350 block. I belive i can use my existing flywheel (if i have it unbalanced first), or can i?
I think the 383 crank is externally balanced since it comes w/ 400's 8" damper.
The second question is: How is the '88 (world class?) T5 going to handle it? The engine is going to be mild (at first) ~ 300hp but ~450lbs/ft.. Or should i just sell the T5 and get something stronger istead of it?
Old Dec 11, 2001 | 03:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Competition Products' catalog lists a weight to use with a standard 350 flywheel to make it externally balanced.
In case you haven't considered it, the '88 block is going to be a one-piece rear main seal design, while most 383 kit cranks are two-piece. An adapter is available to use the two-piece crank in a one-piece block.
I doubt a T5 of any vintage is going to be too happy with a 383 if you ever plan to unleash any of the new-found power.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
[This message has been edited by five7kid (edited December 11, 2001).]
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
italiano67
Sep 22, 2015 08:42 AM
Magman
Sep 13, 2015 12:14 AM
