Question about the difference between tpi and tbi 5.7L blocks
Old Dec 9, 2005 | 06:53 PM
spedrace35's Avatar
Car: 91 camaro z28
Engine: 6.3L, heads, headers, cam,.....
Transmission: 700-R4 w/shift kit and 3-4 WOT kit
Axle/Gears: 4.11
were the tbi and tpi 5.7L blocks different from 87 - 92? Did one of them come with a four bolt mains? And did one block come stock with a hydralic roller cam? Thanks guys for your help
Old Dec 9, 2005 | 07:29 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Theirs a few variances in the engines.
2/4 bolt mains
heads were redesigned, intake bolts now at a different angle
1 piece RMS
Roller cam setups becoming a standard
Probably another half million other things that changed in the late 80s too...
Old Dec 9, 2005 | 08:16 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
just comparing 87-92 blocks (disregarding anything older):
are you talking tpi Fbody blocks, and tbi 350 truck blocks? (no 350 TBI's in f bodies right? )
same block I think, 2 bolt mains all around. Truck 4 bolt blocks was back in the day I think.
tpi's got a roller cam, tbi's got a flat tappet, but had all provisions for a roller cam.
Old Dec 9, 2005 | 08:32 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
4 bolts arent a thing of the past, i do doubt they used them in our gutless wonders though.
My 4 bolt 350 block is an 84, not out of a third gen obviously tho...
Old Dec 9, 2005 | 08:39 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
My old 4 bolt one piece seal, roller cam 355 was from a 1992 G20 van.
The 4 bolt main 350 continues all the way up to today. Mercruiser still builds them as boat engines!
Old Dec 9, 2005 | 09:05 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Yep, using a 4 bolt Vortec 350 short block for my build up.
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
