Will pinned studs have any problem with this?
Old Dec 9, 2005 | 11:05 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have a set of 083 heads with studs pinned. Running 213/219 468 /477 112 cam with CC 986 springs. I am worried about the 132lbs and 280lbs open seat pressures. I saw the 981 springs are 105lbs and 285 Open. Will the 27lbs plus differance really matter? Car will see 5500 RPM max. Any suggs? Or will this be ok?
Old Dec 10, 2005 | 04:26 AM
ede's Avatar
ede
i don't like pinned studs, not that they don't work well for most people. for me i just like to go to screw in studs.
Old Dec 10, 2005 | 12:27 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Once the studs are drilled and pinned they will stand up to anything that you can throw at them. The factory studs themselfs are hi quality case hardened steel. They will not pull out.
I have run pinned studs on motors with lots more lift and spring pressure and rpm (7500+) than you'll ever encounter.
gixxer92
Sep 1, 2015 04:32 PM
transaero
Aug 31, 2015 01:14 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
soarestransam
Aug 24, 2015 08:15 AM
LT1Formula
Aug 20, 2015 09:36 PM
