What's wrong with my 350TPI?
Old Dec 10, 2005 | 02:51 PM
Time's Avatar
Ok, so i install a new fuel pump, fuel filter.
I couldnt wait to order 1 online so until I can I went ahead and bought an accu flow 2P74006 from the parts store. They looked up to make sure it was for a TPI and not a TBI. Mines a 350TPI. The book says (50lbs) pressure.
ok, so It works ok.
Now, I am going to have to maybe replace what seems to be the rear seal leaking in this motor but I want to see what is...if anything...is wrong with the motor. Its been sitting for 2 years. I have new gas in it and heres what it does.
When cold, it cranks right up and runs fine. now after about a min or so, the check engine light comes on and it starts runnig like crap. It does it the same time the light comes on.
After it sits a few hours or overnight, it will crank up and run fine again for about 30 secs to 90 secs and then poof! light comes on and it cuts out and runs rough.
Barely having any power. Its a 1991 Z28 350TPI.
Old Dec 10, 2005 | 04:04 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
have you tried pulling the codes? try and see what the ses/ecm light is trying to tell you.
Old Dec 10, 2005 | 06:15 PM
Time's Avatar
hmmm, never done that. How do I go about it short of taking it to a mechanic?
Old Dec 10, 2005 | 09:23 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
https://www.thirdgen.org/newdesign/faq/thirdgen.shtml
Click Miscellaneous Info and it's right there. The connector is located under your dash probably somewhere relatively close to your fuse panel.
The code will either tell you whats causing your problem seeing that it comes on at the same time....or it will give you a symptom related to your problem, like O2 sensor indicating lean or something.
Old Dec 11, 2005 | 11:00 AM
'87 IROC VERT's Avatar
Car: 2011 BMW X5 35d (diesel)
Engine: 3.5 ltr twin turbo diesel, 425lb/ft
Transmission: 6 speed auto
Axle/Gears: All wheel drive
I once had an '85 TPI T/A that did exactly what you describe. I was too busy at the time to do it myself, a friend of mine replaced one or more relays on the firewall on the driver's side, at least one was toast. That's all he did, and the car ran great after that.
Just thought I would pass that along...
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Dyno Don
Jan 24, 2016 08:24 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
