heater ?
Car: 88 camaro
Engine: 305 non ho
Transmission: not sure
heater ?
i have a ?. my heater is not working . the fan blows. i replaced the temp control valve . and the hoses get hot. just there is no hot air . im thinking a vacume hose is bad or has came off. the heater core should not be bad cause there is fluid flowing throught it . so any help, i would be greatful because its getting really cold out there. o and also if any one has a pis or can send me a pic of the vacuum diagram for an 88 camaro. 305 tbi thank you very much
chris
chris
Car: 88 camaro
Engine: 305 non ho
Originally posted by 85cmroz28
Check and see if your thermostat is stuck open.
The temp of the air is controlled by a little door, that is positioned by a cable that goes to the door from the temp slider on the control head. You can see the lever for the little door under the dash, not too far to the pass side from the hump.
I'd bet the cable is messed up somehow.
Vacuum malfunctions will not cause this.
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
The best way to check your thermostat is to boil it on the stove, and check the opening temperature with a thermometer. I even check new ones before I install them, just to be sure.
