Cleaning EGR passage.
Old Dec 12, 2005 | 04:43 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
Is there a snake oil out there that will aid in cleaning or keeping clean the EGR passage. Last time I had the EGR valve off the passage was pretty well carboned. I am getting an intermitten SES light for an EGR issue. So I'm going to replace the EGR valve soon. While I'm in there, I want to clean the EGR passage. Any tips?
Old Dec 12, 2005 | 05:23 PM
Vader's Avatar
SCrwdrivers, picks, scrapers, a bent piece of still wire, rilfe cleaning brushes, and whatever else it takes to clean the coke and carbon from the passages. AFAIK, there is no magic solution that prevents the buildup.
Old Dec 12, 2005 | 10:55 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
what about polishing the surface? using a dremel say. wouldn't that slow down forming of new junk there?
Old Dec 13, 2005 | 05:27 PM
azvolfan's Avatar
Thanks Vader. The gun cleaning tools is a good idea.
Old Dec 13, 2005 | 06:54 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
And a shop vac to suck up the stuff you loosen up to keep it from falling back into the engine.
Old Dec 13, 2005 | 07:28 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
http://www.pbblaster.com/
and carb cleaner
A wire-wheel works well for the parts you can reach.
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
