Need major help to get my car running right
Old Dec 12, 2001 | 12:26 AM
CamaroRS1990Guy's Avatar
Car: 1990 Camaro RS
Engine: 305 soon to be 383
hey. the SES light came on and it read a code 44. The car would jump when I am driving down the road. Even you can tell by looking at the RPMs. I have replaced the IAC valve and the oxygen sensor.what else could it be.
Chevy Camaro RS 1990
TBI all stock automatic tranny 305 5.0L
Old Dec 12, 2001 | 01:05 AM
ArnoldBraker's Avatar
So basically your driving down the street, the car surges because the rpms are fluctuating, right?
Does it always do this, only at certain times, around a certain rpm level, or speed?
Will the rpms fluctuate at idle? I little more info would be helpful. What size engine and fuel system do you have? My car used to do something similar so I may be able to help you. ~Arnold
Old Dec 12, 2001 | 06:57 AM
Car: 1990 Camaro RS
it is a 305 TBI no it happen at anny speed and even in idle.
Old Dec 12, 2001 | 06:58 AM
Car: 1990 Camaro RS
Old Dec 18, 2001 | 03:33 AM
jasman19's Avatar
Car: RED 1986 IROC-Z28
Engine: 350 5.7L
Transmission: TH 700R4
Axle/Gears: 3.23 10 Bolt
Well I don't know a whole lot bout tbi but I will try and help. I would check for lose connections first. Then you may want to check your tps. Then the last thing that I can think of is a maf sensor. Besides all that I have no idea what the problem is. I would use voltmeter and check the sensors so that you don't have to buy new ones, maybe save some money.
Old Dec 18, 2001 | 05:46 PM
Car: 1990 Camaro RS
thanks i will try that but what will make it give off a code 44
NBrehm
Aug 25, 2015 11:49 PM
jharrison5
Aug 19, 2015 05:53 PM
kyleb24
Aug 15, 2015 08:24 AM
hokis
Aug 9, 2015 03:57 PM
Kaweh
Aug 9, 2015 02:54 PM
