Car Wont Start
Old Dec 13, 2005 | 11:27 PM
CamaroSS_Black's Avatar
Car: 1986 Z28
Engine: L98 Block Vortec Heads Comp Xtreme
Transmission: Built 700R4
Axle/Gears: 10 bolt with Auburn 3.73 posi unit
Car Wont Start
ok i just finished building my engine have it in my car cranks no problem just wont start shoots fire out of the carb some times with a little ether i think its a valve problem i dont know if i tightened them down properly any advice feel free
thanks!
Old Dec 14, 2005 | 08:00 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Double check firing order/plug wires, and timing - you may have dizzy off by a tooth, or even 180*
Old Dec 16, 2005 | 01:56 AM
iroc22's Avatar
Firing through the intake would indicate the power stroke is goofed up somewhere, I doubt it's the rockers. First thing is to check the firing order like said above, then after that check the distributor. Common problem is to be 180 out.
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
