Idling problem
Old Dec 14, 2005 | 10:35 PM
Hrsepowerz28's Avatar
Idling problem
alright well first off i start it up fine, and figure the injectors prob could use some cleaning put some fuel injector cleaner in the tank and well since then it runs good for a minute than it starts sputtering rev it and it gets better but recently even reving it isnt helpin much what is my problem, fuel filter? maf? im confused i have a 85 z 305 TPI
Old Dec 16, 2005 | 12:50 AM
Vader's Avatar
Begin with the basics. Good ignition - distributor cap, rotor, wires, plugs, timing. Check for vaccum leaks, including the EGR and PCV valve, and inspect the inlet ductwor behind the MAF for leakage. Verify clean fuel and air filters, and adequate fuel pressure. Once you have covered the basics, if the problem still exists, check back with further observations. It is possible that some of the injectors are not flowing at the correct rate, or not spraying a good atomizing cone of fuel, but it would be impossible to isolate that without first confirming good ignition, fuel, and compression.
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
