what cam to go with in this solid roller BBC?
This is a 496 with the following:
-Dart Pro1 Aluminum heads 325cc
-Weiand Team G intake
-Holley HP 950cfm
-Crane Solid Roller .615"/.636" 245/254 110 lobe separation, Isky roller lifters, Comp Pro Magnum Rockers, Moroso
I was told this is a baby cam - what kind of cam should I go with, and how much horsepower gain can I expect from it?
-Holley HP 950cfm
Yeah that's pretty small, about a mild street cam in a 496 actually.
I assume this is a bracket racer, looking for 10.20s or so?
You probably need something in the 270-275 degree @ .050" range, probably .675" lift or so.
Check with Bob Cook at www.bulletcams.com
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
