Could really use some help
Old Dec 13, 2005 | 03:34 PM
Cpt. Blasto's Avatar
Car: 1988 Trans Am GTA
Earlier this week I started up my car to move it, then shut it down. A few minutes later I went to start it again, and nothing. All the accesories worked, and I could hear the fuel pump, but no clicking or cranking.
So I check all the fuses, and all of them were good. I took the battery down to autozone to have it tested just in case, but it is good. Then I replaced the starter, since it had been taking longer to turn over, and sometimes it would just click, then do nothing, a few times before it would crank. But it was all to no avail. Finally, I replaced the clutch neutral safety switch. Like I suspected, it didn't help.
I don't know what to do next, any help would be seriously appreciated.
Old Dec 13, 2005 | 03:49 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Turn on the dome light and try to start eng. Does the dome light stay on or go out? If it goes out, check/clean battery connections and ground wire connections.
If it stays on and the intensity stays the same, look for bad connections in the start circuit (ign switch, safety switch, starter connection).
Old Dec 14, 2005 | 11:38 AM
How can I effectively check the ignition switch? I'm not too sure the best way to get at it.
And thanks for replying.
Old Dec 14, 2005 | 11:53 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Have you tried to start the engine by jumping the terminals on the starter, or at least put a test light or voltmeter on the solenoid wire to verify whether or not it's getting juice when you crank it?
Assuming it has no power, you will need to work backwards from there to find why it has no power. As ZZ28ZZ posted, it's probably something in the start circuit. You could probably search around the forum and find a wiring diagram of the circuit.
This car does not have VATS, correct?
Old Dec 14, 2005 | 11:51 PM
It does have vats. Is there a way I can figure out if that is the offending problem?
Old Dec 15, 2005 | 07:14 AM
Lo-tec's Avatar
Have you done this yet?
As for VATS:
https://www.thirdgen.org/newdesign/tech/vats.shtml
Old Dec 15, 2005 | 09:41 AM
Thanks for the link and the advice. I need to find a volt meter to test it with, but considering that the starter is brand new, I'm leary to the idea that the problem resides there.
How would I jump it at the starter?
Once again, thanks for the help. My electrical knowledge is a little lacking.
Old Dec 15, 2005 | 09:46 AM
Lo-tec's Avatar
Large terminal on starter hooks to battery cable and fusible links for power. The small terminal with one wire is what actuates the starter. Use a jumper wire to jump them together to see if it cranks (carefully), OR get a test light or voltmeter to see if the small wire is getting 12V when you turn the key to crank.
Old Dec 15, 2005 | 01:21 PM
I can't get an accurate reading of the crappy multimeter have for my key, but if it was a VATS issue, would I get some reading with WinALDL? Code 46?
