serpentine accessory removal help!! what size torx bit?
Old Dec 16, 2005 | 06:38 AM
dang's Avatar
Car: 85 trans am
Engine: lg4
Transmission: t5
Axle/Gears: 3.27 9 bolt
i have a buyer for the serpentine belt setup off my 89 formula and when i went to remove it, i realised it required torx bits to do so
i dont have ANY torx bits and dont want to buy a set when i never use the things..can anyone tell me exactly what size bit i need in order to remove these bolts..i'd just take a bolt along w/ me to reference it but i kinda cant since i cant get em out
any and all help VERY much apprieciated!
-dan
Old Dec 16, 2005 | 08:41 AM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
I'm pretty sure it is a T55. The power steering pump is a T45. You'll need a power steering pulley puller as well.
Old Dec 16, 2005 | 08:44 AM
dang's Avatar
Car: 85 trans am
Engine: lg4
Transmission: t5
aw man that sucks, wonder what one of those costs..by time all is said and done it wont have been worth selling
thank much for the info
Old Dec 16, 2005 | 09:27 AM
vrtc350's Avatar
Car: 81 Corvette
Naaa, you can get a 3 piece set of torx that includes those sizes at Sears for around $15. Probably cheeper if you have a Harbor Freight around. The power steering tool you can rent from Autozone for free with a refundable $40 deposit. You may be able to get them to do there for you.
Come to think of it, it may be a T50. Buy all three seperate and return the ones you don't use.
Old Dec 16, 2005 | 10:34 AM
LnealZ28's Avatar
Car: 1987 Z28
Engine: 383 Single Plane EFI-NOW RUNNING!
Axle/Gears: Not there yet...
If you're selling the whole serpentine setup, you won't have to pull the PS pump pulley and neither will the buyer unless the pump needs to be removed for replacement or painting.
Old Dec 16, 2005 | 11:42 AM
dang's Avatar
Car: 85 trans am
Engine: lg4
Transmission: t5
thats great to know
thank ya much
toronto formula
Nov 10, 2015 06:17 AM
bamaboy0323
Sep 3, 2015 06:07 AM
mustangdmurder
Aug 21, 2015 07:17 PM
knight72
Aug 10, 2015 09:32 PM
3rdgenparts
Aug 8, 2015 07:09 PM
