89 camaro TPI sensor help quick!
Hey guys,
I am installing a TPI 350 into my jeep cherokee, and need some quick help. i pulled off the (what i think) oil pressure sensor before rebuilding it, now I am not sure where it goes. I thought it whent in the upper hole in the block (middle yellow circle) near the exhaust, but doesnt seem to fit now with the manifold on.
Please help,
Thanks,
Jeff
Please help,
Thanks,
Jeff
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
A picture of the sensor would really help.
It sounds like you're talking about the low oil presure switch. I believe it would go on the bottom right hole. I tried to look on my car but couldn't see it without jacking it up. A 350TPI in a jeep would be great, excellent low end torque. I have 2 jeeps myself and would like to do a V8 swap.
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
It goes in the bottom hole on the right in your picture just above where the oil filter would be.
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
