stalling! please help
Old Dec 17, 2005 | 12:37 PM
tigercyberslash's Avatar
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
hi, my car is been acting up agian. when i go start it up and warm it up , i step on the gas and then it like jerks, like its chokeing,then it will go fast then slow down and bog down. then if i hold the pedal down long enough it will start to pick up rpms and drive sumwhat normal. and when i completely step on the pedal down it shuts off, when i release my foot it turn back on. sounds like to me something is cloged, like not enough gas is getting to the carb or something. can someoen help me please.
injectors maybe? i dunno just please help if u can
also the check engine light has been n for a couple months. but it ran fine , also i gott to lift off teh pedal after 1st gear to switch. but thats probably due to my trans leak
Old Dec 19, 2005 | 03:51 AM
StaticVertigo's Avatar
so its a 305 TBI z28 with possible clogged injectors and a faulty carb? heh.
Old Dec 19, 2005 | 11:08 AM
Engine: V8 350 ci
What is your point? please dont post if your you dont got any helpfull advise. thx
Old Dec 19, 2005 | 08:40 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
His point is you gave a half assed description of the problem.I can tell from reading your posts that even if it could be diagnosed on here,you've got no buisness tearing into it yourself if your that unfamiliar with your car.
Old Dec 19, 2005 | 10:01 PM
Engine: V8 350 ci
like i said, i know how to fix the things on my car, just i cant find the problem, i already replaces the manifolds, cat, heater core and alot of other minor tuff, so i know enough how to fix it, just nothow to find it. so i repeat, please dont say stuff if ur not tryign to help.....if u need to know more info, please just ask.....
Old Dec 19, 2005 | 10:34 PM
ssscarpone's Avatar
Car: 1983 Pontiac Trans Am
Engine: 305 Crossfire V8
Transmission: Autotragic
Re: stalling! please help
That must be a new kind of fuel system... a CARBOJECTOR
Dude your not gonna get any help with a ****head attitude like that.
Check your fuel pressure then the timing and so on...
Old Dec 19, 2005 | 10:42 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Have you ever thought that the SES came on for a reason?
I.e. Pull codes?
The SES light doesn't come on for shoots and giggles...
Old Dec 20, 2005 | 01:39 PM
Engine: V8 350 ci
I.e. Pull codes?
um ya i think i know that.....but how do i find what code NUMBER it is, u need a certain toool? and how do u check fuel pressure
Old Dec 20, 2005 | 04:22 PM
ssscarpone's Avatar
Follow the link for finding ecm codes https://www.thirdgen.org/techbb2/sho...ight=ecm+codes
For fuel pressure put a fuel pressure guage inline and see what it reads..
Old Dec 20, 2005 | 06:23 PM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Use a paper clip that is bent into a horse shoe and stick it in the a/b connectors on the far right on the top row of pins. Turn the key on and wait until the s.e.s light blinks its codes out. You should get a 12 three times before the trouble codes start coming out. You also might want to check the P.C.V. valve to make sure it isn't clogged. The E.G.R. valve will throw a trouble code if it's the problem. As will the O2 sensor. Another thing worth checking out is the airfilter. Hope that helps.
Old Dec 20, 2005 | 06:32 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
also, just to be clear, does the car have a carburetor, OR, TBI injection? may make it easier...
But yea, pull the codes, then decode them from the website linked, and/or post them here. ie, if the code is "EGR", EGR may not be the only thing wrong there.
Old Dec 20, 2005 | 07:33 PM
Engine: V8 350 ci
it is tbi
Old Dec 20, 2005 | 07:51 PM
Engine: V8 350 ci
ok i teh engine codes....i got the following error codes...
23
32
44
now whats next?
Old Dec 20, 2005 | 08:21 PM
Sonix's Avatar
Car: 1982 Trans-Am
ok, as per usual, the problem could be one of a million things...
32 = EGR, I know that one by heart...
23 = MAT low temp
44 = 02 lean
My guess would be a vacuum leak. You replace the manifolds lately, would that be intake by chance? (just thought i'd check...)
if you have a vacuum gauge, hook it up and see what idle vacuum level is. maybe a can of starter fluid to try and find a vacuum leak.
Anyway, that's my guess, any other opinions?
Old Dec 20, 2005 | 08:27 PM
Engine: V8 350 ci
23 = MAT low temp
44 = 02 lean
well the left manifold was replaces when i first got the car, i was told my left one needs to be replaced. i dunno, maybe it acting up... should i take it to a mec at this point?
Old Dec 20, 2005 | 10:09 PM
Irockz's Avatar
Um,yeah.Seems as though someone already told you that stupid.Congrats on your newfound ability to spell,however.
Old Dec 20, 2005 | 10:27 PM
ssscarpone's Avatar
Haha wheres the love man???
Just take a can of starting fluid and spray the intake and plenum gaskets and see if the idle increases...Then spray any vacuum lines to see if there is an idle increase.
Old Dec 20, 2005 | 10:44 PM
Irockz's Avatar
Lost my love for this guy long ago.Really good at asking questions,terrible at listening to answers.
I'm a really nice fellow normally,however.I just feel that honesty is a real good thing,kind or not.
Old Dec 20, 2005 | 11:01 PM
Engine: V8 350 ci
wuts a plenum? where is it
Old Dec 21, 2005 | 06:35 AM
ssscarpone's Avatar
the plenum is the rectangle looking plate that bolts to the top of the intake manifold...and your cfi's bolt to it.. But you dont have a cfi setup, so just worry about the intake manifold and vaccum lines.
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
