HElp
Old Dec 17, 2005 | 03:58 PM
FLTraumaRN's Avatar
Car: 1988 Z28
Engine: 357 ci 472 hp at RWs
HElp
Hey guys did my engine swap and everything works well. By the way didn't keep EFI went with carb system because I had a V6 car any way was wondering about all the left over wires that no longer belong to anything and have no power running to them could I or do you recommend cutting and gutting the wires. kept everything of importance (lights, ignition, fuel pump, wipers, AC and ALTernater. any comments or if anyone knows of a front end after market harness thanks Bill
Old Dec 17, 2005 | 07:45 PM
zimmchile7's Avatar
Car: 1985 Trans Am
Engine: 383 Stroker
If you don't plan to use them again I would just disconnect them from the computer behind the dash or cut them. Also pull out your check engine bulb so that it's not embarrasing when you take a date out and she thinks your car is messed up.
Mine are zip tied out of the way right now but it's really ugly and I plan to remove them completely. Not to mention they really get in the way when doing spark plug changes and compression checks.
