building a high powerband motor
Old Dec 17, 2005 | 08:51 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
My next motor will be something that can make power at a high RPM. I was thinking something along the lines of 3500- 7500. I know of one guy on here running one and i was curious to see if anybody is running this kind of setup.
What cam, heads, and intake setup did you go with?
Anything special done to the bottom end?
Old Dec 17, 2005 | 09:16 PM
daverr's Avatar
i plan on running that high, actually higher .my bottom end is all forged.Not too many ppl run it that high on this board.I think if build a good bottom end u shouldnt worry about spining the motor high.
im running brodix 18c heads.Brodix intake.Crower shaft rocker setup.I still have to buy a cam(solid roller of course).
After seeing some Small block motors making 800+hp NA i was hooked.
goodluck on your project.
Old Dec 17, 2005 | 10:24 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: building a high powerband motor
Make a good selection on parts and build it well. Very well. If the top end supports, the bottom end (assuming it's strong) will follow.
Rules forced the 23° valvetrain for me.
Old Dec 17, 2005 | 10:44 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
Also think about taking a 400SB and de-tuning it. making it only displace out 350 or 383. Its also called de-stroking. i have known many people who have effectivly built these to run up to 10,000 hp (full drag motor wouldnt recommend that high of a powerband)
italiano67
Dec 11, 2016 09:21 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
69 Six Pack
Oct 5, 2015 07:51 PM
E Rod
Aug 28, 2015 05:17 AM
