new O2 sensor,but....
Old Dec 19, 2005 | 05:47 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
the old one will not come out,a 7/8 crowsfoot helps get to it,but it just wont budge
followed the set minimum air since the O2 sensor won't budge with engine warmed up.and after 30 seconds or long with ALDL jumped across,turn off key and remove paper clip,disc the IAC,when restart the car it idles wildly,way fast over 3K,no adjustment to torx screw has any effect at all,WTF,shut the car off b4 she blows,reconnect IAC and back to a 1500 idle???just gonna drive the thing until it blows,this car is really annoying me,
Old Dec 19, 2005 | 05:54 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Penetrant and a cheater bar?
Old Dec 19, 2005 | 06:03 PM
f50nut's Avatar
Car: 88 GTA, 00 SS
Engine: L98, LS1
Transmission: 700R4, T56
^^what he said
spray the thing with WD a few times a day for a couple days..then have a go at it
Old Dec 19, 2005 | 07:34 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
If you wanted to have some fun heat up the bung cherry red and pour some Ln2 on the sensor, it should pop right out!
More practically, 3' cheater bar...
Old Dec 19, 2005 | 08:24 PM
spifman's Avatar
Car: 1986 Camaro RS
Engine: 305 V8
Transmission: 700r4 automatic
There's this stuff called "Deep Creep" that autozone sells, it's worked great for me in the past. Just spray the crap out of it for about 30 min, and you're good to go.
Old Dec 19, 2005 | 10:39 PM
hwcoll95's Avatar
Engine: 355 carb'd
Transmission: 5spd
liquid wrench
soaking it with liquid wrench about every 30 minutes,then tapping on crowsfoot extension ,gonna keep this up ,then jack it up in the morning and get on it with boxed end from the bottom,still confused on the min air setting,went crazy on me today,someone says once jumpered ALDL and key turned on for the 30 seconds,not to turn key off to remove jumper,and while running hook IAC back up??
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
