problem replacing fuel filter
Old Dec 20, 2005 | 12:23 AM
Spazz698's Avatar
Car: 88 Camaro, 93 civic hatch
Engine: 2.8L, 1.5L VTec
Transmission: 5 Speed, 5 Speed
I noticed my fuel lines (and the filter...and the stabilizer bars, diff, etc etc) are rusty. I tried replacing my fuel filter earlier while I had access to a lift and I cant get the thing to break loose. I used penetrating oil with no luck. Not trying to break the lines since this is my daily driver for the time being, but any good ideas on how to get the thing loose or should I just leave it be til I can get the lines replaced?
Old Dec 20, 2005 | 11:43 AM
Firebat's Avatar
I would just wait til you get new lines.
Old Dec 20, 2005 | 02:22 PM
'86 350's Avatar
Car: '86 Camaro SC
Definitely wait until you get new lines too. I made the mistake of breaking mine loose anyways and it snapped clear off.
Old Dec 20, 2005 | 02:35 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
PB'Laster Penetrating Oil
accept no substitutes
WD-40 is crap... I still use it around the house, but when I need something to actually penetrate rather than lightly lube.....
PB'Laster
Old Dec 20, 2005 | 02:55 PM
'86 350's Avatar
Car: '86 Camaro SC
I was using PB Blaster, still snapped the lines.
Old Dec 20, 2005 | 04:11 PM
Car: 92 RS
Engine: a slow one
then you sprayed it wrong
haha
Old Dec 20, 2005 | 05:47 PM
The Chad's Avatar
Car: 84 berlinetta
Engine: lg4
Transmission: 700 r4
I twisted and broke the fuel line on my son's 89 305. All it took was a kit from napa and a little measuring and a tube cutter. I think it reconected with a compression fitting if that's the right term?
Old Dec 21, 2005 | 05:54 PM
zimmchile7's Avatar
Car: 1985 Trans Am
Engine: 383 Stroker
try aero-kroil if you can find it for a penetranting lube. I use it on airplanes and on my truck for suspension work (283000 miles makes a lot of rust). I get it from aerospace products international but I'm sure you can find it elsewhere. Also ZEP 45 works pretty well too.
Old Dec 21, 2005 | 10:42 PM
Spazz698's Avatar
I used the penetrating oil we use at work...so all I know is it's industrial grade, not the cheap stuff.
but naturally rather than breaking my fuel lines since I decided against doing it I managed to break a stabilizer (torsion? I forget the right name for them) bar. They were that rusty and the recent rain (not to mention the deicing crap they use on the hills near my house) made it finally give way. My driving might have been part of it too...lol
Old Dec 21, 2005 | 11:04 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
You mean rear lower control arm or tracking bar?
Old Dec 21, 2005 | 11:24 PM
Spazz698's Avatar
the 2 bars that cross near the differential. So far Ive heard them called 3 or 4 different things. I havent really had to deal with non-motor/tranny type issues up til now if you couldnt tell lol
[edit] Now that Im looking, Its the control arm. I busted the driver's side one. Im on the hunt for a pair of aftermarket ones [/edit]
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
bryan623
Mar 22, 2021 06:43 PM
Brcharrelson
Aug 26, 2015 07:47 PM
92camaroJoe
Aug 13, 2015 06:07 AM
