no start w/o starting fluid
Well, that would clearly be a no-fuel situation.
Gas tank is KNOWN POSITIVELY not to be empty, I take it?
Check the fuel pressure, and the injector fuse (labelled "ECM" in the fusebox IIRC).
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
nah... he said it only starts with ether... he didn't say it doesn't start at all, which would be the case with no fuel.
he gets fuel (he must if it is running)
but not like we can tell, since he posted exactly one sentence......................................
more info is needed to help you
only when its cold?
starts fine when it warms up?
runs good? runs roughly? does it ping?
does it get good spark?
this isn't a magic site... you have to do SOMETHING you know.............
only when its cold?
Car: 1989 camaro rs
Engine: 305 tbi
Transmission: t 5
it cranks but does not start if i spray it with starting fluid it will start right up and stay runnig fine the next day got to spray all over agin
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
I had a problem like that with my 84 cavalier. It turned out to be the temp sensor, believe it or not. Are you throwing any trouble codes?
Car: 92 RS
Engine: a slow one
yeah
something like that has alot of possibilities though... this guy needs to do some slight troubleshooting or analysis of the situation and post the results at least.
backtothe80s
Sep 5, 2015 12:39 AM
92camaroJoe
Aug 13, 2015 06:07 AM
