Checklist for no spark
Subscribe
Dec 22, 2005 | 01:28 PM
1989 Trans Am 350 TPI
Okay so my car died and I checked and its not getting any spark. I don't know where to start - is there a list of things that I should check or test before I go replacing stuff? If I do have to start replacing ignition parts, where should I start? Sorry I've never dealt with this kind of problem before. Any help would be greatly appreciated. Thanks!
Chris
Reply 0
Dec 22, 2005 | 07:48 PM
Fusible link, HEI module, coil, coil wire, wet distributor cap, ignition switch, any wiring, pickup coil/reluctor, shorted tach, and about a hundre others. You best friend will be a volt/ohm meter. Check for power at the coil first. That will split the list right in half.
Reply 0
Subscribe
