Engine noisy! Any ideas?
Old Dec 20, 2005 | 07:29 PM
89GTA2LV's Avatar
Car: 89 Trans AM GTA
Engine: 5.7L
Ok,
I have a 89 GTA 5.7 61k on the odometer.
I bought it from the original owner and noticed when I go up a hill with the gas pedal to the floor or take off from a light with the gas pedal to the floor, I get the wonderful growl and then at about 30-40 mph I get a crackling sound from the motor. It goes away after about 2 or 3 seconds.
I just had a complete tune-up Plugs, wires, etc. Car runs better but this cracklin sound is still there. Any ideas?? Keep in mind, if it makes any difference, the plugs, cap & wires that were that were replaced were original equipment.
Please help!!
Old Dec 20, 2005 | 08:20 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
What octane fuel is in the tank?
Old Dec 20, 2005 | 08:21 PM
89GTA2LV's Avatar
Engine: 5.7L
I've tried super and it still does it.
Old Dec 20, 2005 | 08:43 PM
F-BIRD'88's Avatar
Catylitic converter heat shield rattleing? or Engine detonation (pinging)?
Old Dec 20, 2005 | 08:53 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
I'm gonna take a random guess, so I could be wrong...
The noise only occurs when the drivetrain is under the greatest strain. Maybe somehow the U-joints are worn out, but only make noise when the rear end geometry changes just right...
Old Dec 20, 2005 | 11:24 PM
89GTA2LV's Avatar
Engine: 5.7L
It sounds like pinging but I do not know what the Cat heat shield rattleing would sound like??
Old Dec 22, 2005 | 03:18 PM
F-BIRD'88's Avatar
Lean air fuel ratio.(clogged injectors, low fuel pressure.... or excessive ignition advance.
At what rpm (range) does it ping?
Old Dec 22, 2005 | 09:44 PM
89GTA2LV's Avatar
Engine: 5.7L
I will have to check, I know that it happens only when completely open and at a higher rpm. The exact, I will need to check.
NinjaNife
Aug 23, 2015 11:49 AM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
