Solid rollers for 87 and up blocks?
Old Dec 24, 2005 | 10:34 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Does anyone make solid roller lifters that work on the 87 and up blocks? Useing the factory retaining spider and such?
Old Dec 24, 2005 | 10:54 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Not that I'm aware of. Companies do, however, make lifters that are .300" taller to clear the factory roller blocks. I have a set of Isky SR lifters that are designes as such.
Old Dec 24, 2005 | 12:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I just happened to read a Comp Cams project on getting more out of a 350 HO crate engine. First they converted it to factory roller hydraulic lifters, then tried a solid lifter version. The solid cam was old-style, so they had to use a cam button. For lifters, they went with their 888-1 bar-style retros. Since they had a choice of anything off their shelf, that they chose retros is telling, I'd say (they didn't say why they chose them in the article, just that they're what they used).
Old Dec 27, 2005 | 03:42 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
I've seen solid rollers for the LS1 engines popping up in magazines, from what I've heard this is one of the only things the LS1 shares with the older style small blocks, may be worth looking into.
Old Dec 27, 2005 | 08:46 AM
five7kid's Avatar
Okay, try this: www.summitracing.com .
Click on "online catalog" over on the left. Then make these choices:
Engines & Components, Camshafts & Valvetrain, Lifters, Chevrolet, V8, 5.7L/350, Chevy small block Gen I, Mechanical roller. At that point 4 choices will appear, and you'll see only one has a picture that looks like factory roller lifters. It's the Crane CRN-10510-16, $360.69 for a set of 16. If you click on the p/n, this note will show up: "Long travel design for use with standard GM alignment bars in engines originally equipped with hydraulic roller lifters."
TX-SleeperC5
Feb 24, 2016 01:34 PM
Jorlain
Oct 8, 2015 01:57 AM
RyanJB
Sep 14, 2015 03:39 PM
Nick McCardle
Sep 10, 2015 08:36 PM
