4.3 Liter engine/Transmission Question
Old Dec 27, 2005 | 09:26 PM
DeanHensler's Avatar
I've got an 86 monte carlo sport coupe. Its got a 4.3 liter V6 with an automatic transmission. I'm turning it into a race car, which will have a 350 with a 3 speed manual transmission.
I know the bellhousing pattern on the 4.3 liter is supposed to be the same as the 5.7 liter 350. When I went to bolt the 350 bell housing up to the 4.3 liter engine the starter was interfearing. The bellhousing has a provision for the starter, but it didn't match up with the starter on the 4.3 liter.
My question is,
1. Does a 4.3 Liter engine use a different style starter than a 350?
2. Does an automatic transmission require a different starter than a manual?
I'm trying to figure out where my missing link is.
Old Dec 27, 2005 | 09:34 PM
This is what my current bellhousing looks like.
Old Dec 27, 2005 | 09:57 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Stock car racing are we?Don't know what's interfering here,but you can bolt a 350 starter to the 4.3 if need be.
Haven't seen you on the stompers site in a while,have you left us?
Old Dec 27, 2005 | 10:11 PM
So what you're saying is that starters are different for automatics than they are for manuals right?
Yea, I'm switching sports for a while. Couldn't pay for the gas to tow my mud racer 2 hours every time I wanted to race.
I see you're from Springfield, whats your name?
Old Dec 27, 2005 | 10:42 PM
Irockz's Avatar
Does Big Red ring a bell?
Not sure.but I do know that if you've got a starter that jives with that bellhousing,it'll bolt to the 4.3 just the same as a 350.
Old Dec 27, 2005 | 11:12 PM
Oh yea, I thought you lived in Brighton.
I've done some research and here is what I've found. My bellhousing is casting number 3899621. Identical to this.
http://cpucarparts.com/welcome.asp?h...rProductID=R76
Now, that says its for an 11 inch clutch. I've got a stock 10.5 inch clutch. Will this bellhousing still work, or do I need a different one?
If it WILL Work, what kind of starter do I need to get for a 350 that will work with the 10.5 inch clutch and this bellhousing?
Old Dec 28, 2005 | 09:12 PM
Damon's Avatar
What size flywheel/flexplate are you using? The problems usually begin when you start playing mix-n-match between 153 tooth flywheel/flexplate applications (pass. car stuff, standard duty parts) and larger 168 tooth ones (typically truck stuff/heavy duty applications).
4.3s could be had with either size flexplate/flywheel just as 5.7s could. To my knowlege the starters will physically interchange between a 5.7 or 4.3 with the same size flexplate/flywheel (although I don't think the 4.3 starters are as heavy duty as the V8 units).
Bubbajones_ya
Aug 31, 2015 12:02 PM
dyeager535
Aug 28, 2015 08:10 AM
Thornburg
Aug 27, 2015 08:28 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
