Are these springs causing my skip?
Old Mar 30, 2006 | 03:07 PM
  #51
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Couple of questions:
-how did you bolt the spider in the valley on a non roller block?
-did you have to go with a really odd pushrod length?
-since the lifters are shorter and you are using a small base circle cam, how close does the top of the lifter come to the bottom of the retainer?
Old Mar 30, 2006 | 03:42 PM
  #52
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
My guess is he drilled and tapped the bottom to attach the retainer spider, but I'd have to check with him. I also imagine he just flexed the fingers on it a bit to contact the lifters, can't say for sure on that part. As for the Trick Flow push rods he used, if I remember correctly, they're 7.500 length. And the valve springs are Comps with the orange stripe that are supposedly good for .600 lift (although I can't confirm that).
Old Mar 31, 2006 | 08:32 AM
  #53
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
I took a look at my lifters yesterday to try and see if they were the cause of the problem. I loosened them all up till they made noise and see if the the motor improved at all....it did not. Also when I loosened them I could see the pushrod start to move up when the spring pressure was removed so I can say they are not stuck solid.
vernw..Id pull those out and get yourself a set of retro-fit hyd rollers and then revisit pushrod length and valvetrain geometry. Those lifters seem to be very different than what is used on a V8..also I wouldnt trust them with a higher spring rate than stock...
87v6Bird
Jul 1, 2018 04:12 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Zane Story
Oct 8, 2015 12:40 PM
sandman92084
Sep 12, 2015 10:27 PM
